Case 310B TSX635 Choker Fly Flapper Spring
Scott Flynn
10-01-2005 21:39:13
I took the carburetor apart for my tractor this weekend and noticed that someone had installed the choker upside down and there was no spring on the flapper. Anyone know where you can get one of these? The parts book shows the number to be "24-A43", but I don't think that this is a good part number any longer. Thanks.
Glen in TX
10-02-2005 10:19:28
 Re: Case 310B TSX635 Choker Fly Flapper Spring in reply to Scott Flynn, 10-01-2005 21:39:13
You should be able to get the whole choke butterfly and or shaft & butterfly assembly.
Scott Flynn
10-04-2005 12:26:20
 Re: Case 310B TSX635 Choker Fly Flapper Spring in reply to Glen in TX, 10-02-2005 10:19:28
I tried that. CaseIH no longer supplies them. I haven't been able to locate them anywhere else either.
Glen in TX
10-04-2005 12:37:27
 Re: Case 310B TSX635 Choker Fly Flapper Spring in reply to Scott Flynn, 10-04-2005 12:26:20
Zenith doesn't show me a part number for the TSX 635 choke butterfly but does give me some numbers of parts available for the Marvel Schebler. If you have a part number for me or can give me the throttle bore size and outside diameter of choke butterfly I can cross it or match it and tell you if I can get it from Zenith. Just put a new choke disc in one for a welder carb and it was available from them. Email me with the info.
Scott Flynn
10-11-2005 04:57:46
 Re: Case 310B TSX635 Choker Fly Flapper Spring in reply to Glen in TX, 10-04-2005 12:37:27
The choker fly assembly is 27-550. Thanks
Glen in TX
10-11-2005 09:46:59
 Re: Case 310B TSX635 Choker Fly Flapper Spring in reply to Scott Flynn, 10-11-2005 04:57:46
Okay Scott, I couldn't cross that number but sent you email with more places to try. Good luck.
