teeth on drive sprocket
SC puller
10-01-2005 16:41:11
Does any body know the number of teeth on a s sprocket verses an sc. I would like to get a little more speed out of first gear on my SC puller.
Don Livingston
10-02-2005 08:01:50
 Re: teeth on drive sprocket in reply to SC puller, 10-01-2005 16:41:11
I believe the S / SI / SO tractors have 36 teeth and 45 for SC's. Don L.
sc puller
10-02-2005 09:30:46
 Re: teeth on drive sprocket in reply to Don Livingston, 10-02-2005 08:01:50
Thank's
L.Lamp
10-02-2005 15:52:01
 Re: teeth on drive sprocket in reply to sc puller, 10-02-2005 09:30:46
At 4600#, my '54 SC won't spin the tires in 1st gear or even pick up the front wheels. It tests 30+ hp on the dino. It runs stock rpm. Are you running above stock rpm? My tires are 11.2x38 Titans with 12# air. I just want to pull in antique class, no hotrod stuff. I run out of power every time I pull and have given up on it as a puller of anything but a float!!
sc puller
10-02-2005 22:44:11
 Re: teeth on drive sprocket in reply to L.Lamp, 10-02-2005 15:52:01
My 43sc has spoked rear wheels so I can pull 3500lbs. I can never hook up in 1st gear in 3500lbs and I dont have enough power for 2nd gear. It has stock motor and I took second place on Saturday in 4000lbs.
