DC pressure gauge
Ia Roy
09-30-2005 19:33:12
On my 51 DC the oil line goes to what looks like a pressure sending switch that is right under the gauge. It looks like there should be wires to it but there aren't any. Can anyone tell me what this and where the wires should go?
Camboted
10-01-2005 08:38:27
 Re: DC pressure gauge in reply to Ia Roy, 09-30-2005 19:33:12
You must have some kind of aftermarket retro-fit gauge. The original oil pressure guage operated of of a copper tube that tee'd into the line that ran over to the oil filter at the left rear corner of the engine block. No wires are needed. It could be that you have a SW gauge that has provision for a light, in that case, if you want a night light hook up the wire to the light switch. LOL. There is an ebay store that offers parts. The link is:
http://stores.ebay.com/Saeli-Implement-Tractor-Parts_W0QQssPageNameZviQ3asibQ3astoreviewQQtZkm
L.Lamp
10-01-2005 10:35:38
 Re: DC pressure gauge in reply to Camboted, 10-01-2005 08:38:27
You may have a low oil shut down switch that was used on the DE Engine Units. If it is about 4" long with a plunger on one end, that is what it is. It aslo has a provision to bolt it securely to the tractor with 2 bolts.
