Bearings and Seals for 1951 VAC
Gafarmboy
09-29-2005 13:59:47
Morning all; Finished redoing the Case about 2 years ago with the boys. Did the usual paint, tires,decals,seat,etc. Well now I have developed an oil leak from the front tranny seal, and it is a gusher. I also noticed that the Steering bearing on the front axel has gone south. Where can I get new ones. Any and all advice would be welcomed.
Thanks in Advance
Gafarmboy
Keith-OR
09-30-2005 13:55:44
 Re: Bearings and Seals for 1951 VAC in reply to Gafarmboy, 09-29-2005 13:59:47
Go to the following website, click on "Restoration Tips" then go to "Misc. Case info"..
HTH..Keith
GA Case
09-30-2005 05:46:59
There are two seals on the input shaft between the hydralic tunnel and the transmission. These seals are Case # VT4970. The replacement seals are from Napa # 11800. The paper gasket could have a break in it as well. These seals will fail if the hydralic fliud is alllowed to run low. This all requires cracking the tractor in half. Good luck on finding the leak.
