chugging 1370
jvks
09-28-2005 18:52:40
I am having a problem with my 1370 tractor chugging (by chugging it sounds like an old locomotive but a little faster) does this off and on sometimes it runs fine at a smooth steady speed. Chugging or pulsating will happen with or without a load more pronounced at higher throttle settings. If I were to guess it seems as if it has something to do with the governor. hope to hear from someone who might have experienced the same problem. Thanks in advance
c. hess
09-29-2005 14:16:01
 Re: chugging 1370 in reply to jvks, 09-28-2005 18:52:40
After you have checked other suggestions an are satified they are not problem you can remove the larger cap on rear of inj pump (11\16 will fit)you should hold narrow part from turning. when you have the cap removed turn screw with engine running till you increase speed.Back off screw slightly an put cap back on. I think you may have a condition called (looping)you might have to remove safetyseal on cap. Let us knowhow you do
John Saeli
09-29-2005 06:18:27
With my luck, it'd be something like what Jim & D Kase suspect. But, 1st, I'd look at fuel delivery to the pump. Plenty of fuel flow to the Sediment Bowl? I have a problem with moss plugging the line on our 1175 once a year or so. Replaced the Filters?
jim handke
09-29-2005 06:00:48
The pump on my 1070 did the same thing. It had severe wear internally, both the throttle rod and rack. If the cab mounts are tight, I"m afraid removing the pump and sending it off is your last option.
DKase
09-29-2005 05:29:21
Check your cab mounts. If the cab is loose it will vibrate the throttle. Disconnect the throttle would be a good check for this. It could also be a weak spring in the governor. Mail it to Jerry at Steffen Repair in Crofton NE. His phone is 402-388-4990. He will fix you up really reasonably. Good Luck DK
