Hydralic tunnel tapered roller bearings for 52 VAC
Ga Case
09-28-2005 12:20:47
The front roller bearing in the hydralic tunnel has locked up. I pulled the shaft and removed the old bearing. It is a Bower 14 116 (most have been changed sometime through the years, no VT in the number). I have not been able to cross reference this bearing anywhere. Any ideas would be helpful.
Joe (Wa)
09-28-2005 18:21:08
 Re: Hydralic tunnel tapered roller bearings for 52 in reply to Ga Case, 09-28-2005 12:20:47
From Case VA series tractors parts catalog R.I. E61:
VT4882...Cone - bearing, clutch shaft (Timken #14116).
VT2097...Cup - bearing, clutch shaft (Timken #14276).
Joe
GA Case
09-29-2005 12:32:30
 Re: Hydralic tunnel tapered roller bearings for 52 in reply to Joe (Wa), 09-28-2005 18:21:08
Thanks for the info, found the parts needed.
