leaking return injector pump
Don Henderson
09-28-2005 11:49:22
I have a Case uniloader that I haven't had very long. It runs okay but I noticed fuel leaking around the fuel return line at the pump and also at one of the supply lines to an injector (also leaking at the connection on the pump side). I'm not much of a diesel mechanic but does this sound like I need to have someone come out to look at it or since it's running okay should I just live with the slight leak? Thanks, Don
Glen in TX
09-28-2005 16:33:56
 Re: leaking return injector pump in reply to Don Henderson, 09-28-2005 11:49:22
Well Don I'm not that familiar with this rig but if you can turn a wrench you may be able to fix the leaks. If the fittings have those sealing washers on them that might be all you need to replace. Sometimes if they have leaked for too long the fittings get wore or warped and or lines and have to be replaced too. Check with your dealer parts man and see what is needed and then you can decide if you can do it.
