overhead oiling
wddge
09-27-2005 20:26:59
I have a 1933 case and was told this weekend that I should take the rocker cover off and oil the top end every so often because they do not punp oil up there, My qeustion, is this true or just another tale form outer space???
Camboted
09-28-2005 08:20:14
 Re: overhead oiling in reply to wddge, 09-27-2005 20:26:59
I have heard of people running a copper line up to the rocker arm assembly and installing a pressure lubracation system. That is basically what was done of the DC and LA. It will definately cause your rocker arms to last longer and it will run smoother.
wedge
09-27-2005 20:28:58
Forgot to say it is a model C.
thanks for any information
wedge
casenut
09-28-2005 06:38:23
 Re: overhead oiling in reply to wedge, 09-27-2005 20:28:58
I own 2 model C's a model CC4 and a model L and they all need to have the rockers oil periodically. I would advise you to buy an owners manual for your tractor. It will explain all the lubrication and maintenance. (no outer space stuff here)
wedge
09-28-2005 10:04:36
 Re: overhead oiling in reply to casenut, 09-28-2005 06:38:23
Thanks for the inpute I will pull the rocker arm cover and oil today, where would a person find a owners manual, I have been trying to find on?
L.C.Grey
09-28-2005 15:47:07
 Re: overhead oiling in reply to wedge, 09-28-2005 10:04:36
Since mine only come out for weekend shows I will usually oil them on Friday evening and use something like Lucas or STP thats thick and will remain in place longer. That way I oil it up before loading on the trailer and it will stay oiled for the short times time it will run over the weekend and still be lubed to unload and park back in the barn when I get home. You also should drain some oil from the lower check plug on the pan and pour it into the governor housing as well. When the enigines were modified later for upper end oiling they alson made provisions for oil to the governor as well.
My "34 C and '36 CC require manual oiling but someone has long ago fitted my '29 L with external oiling and a "Luberfiner" bypass filter. Its sure convienient not to have to go throught the process of removing the airstack, hood and valve cover each time.
Bob in Australia
09-28-2005 21:44:55
 Re: overhead oiling �question for L C Grey in reply to L.C.Grey, 09-28-2005 15:47:07
Could you please give some detail on how you set up the external oiling and the filter?
I have a 1936 C that I would like to put external oiling on. I also have a 1938 L and 1944 and 1949 LAs that I wuld like to put filters on.
Thanks
L.C.Grey
09-29-2005 19:36:14
 Re: overhead oiling �question for L C Grey in reply to Bob in Australia, 09-28-2005 21:44:55
I've never done one or even looked inside the crankcase of a C/D engine, but someone I know who is very knowlegable with these engines told me to do it you tee'd off the tube to the oil pressure indicator and snaked a tube up the pushrod side of the block and made either a fine spray bar or drip pan to lube the rockers.
I intend to do both mine some day but would also like to include provisions to drip oil the governor housing as well.
I do think it would be a good idea to either solder a jet in the tube or place a cap tube in the line to limit the amount of oil to the top end to hold pressure in the bottom end first under all conditions.
I actually have a complete spare set of rocker arms and shafts with the idea of drilling through lengthwise and tapping the ends for fittings and placing small bleed holes to lubricate each rocker arm. Once I build a set I'll swap em in and make another set with the ones I replaced. All I lack is... time.... as usual.
Camboted
09-28-2005 22:05:00
Someone on the forum explained the process a year or so ago. They ran a copper line up through the block, so, everything looked original on the outside. I believe they just did the DC thing on a CC. You are a clever engineer and can figure it out. Right? You might need a set of DC rocker arms? But I've little experience with the CC's I am hoping the guy who did the work will jump on and explain it. LOL!
DKase
09-29-2005 05:54:03
 Re: overhead oiling �question for L C Grey in reply to Camboted, 09-28-2005 22:05:00
I'm afraid that was me, and now I am on the chopping block to explain it again. I tapped a fitting into the oil line on the main bearings, and ran a soft copper line around the camshaft, and push rods, and up to the rocker arms where I used DC rockers that oil through the center. I had to fabricate a clamp to hold the copper tube just above the camshaft. There is not much room in there. Since my engine is on a crawler I plugged the fitting just off the main bearing and drilled a 1/16" hole in it so if the copper tube cracked or broke from vibration I would not loose all the oil pressure and trash the crankshaft. It was much easier to do with the engine on an engine stand. It would be quite a job laying under the tractor and reaching up in there. Lots of luck DK
mshultz
09-29-2005 04:54:28
I recently put together a C and put oiling system on it, but it does not look stock if you're woried about the correct police coming around. I gutted the oil pressure indicator and ran a pipe into the elbow that usually goes to it. It was either a 1/4" or 3/8" pipe, and with a couple hits with a hammer to make it a little oval shaped it fit just perfecly with a little silicone to seal it up. From there it looks like a 9th grade plumbing project. I put an elbow at the end of it, have a T for a pressure guage, have another T for oiling the Distributor (from a DC), and then a soft 1/4" copper tubing up to the valve cover. I drilled a hole in the top front and ran a soft copper line along the inside of the valve cover directly over the rocker arms, and drilled small holes over each rocker arm. I haven't had it off yet to see how good of a job it's doing, but seemed better to spend time doing that once than ripping the thing apart every weekend to oil it.
Brian in Ohio
09-28-2005 19:53:34
 Re: overhead oiling in reply to L.C.Grey, 09-28-2005 15:47:07
The previous owner of my 34 L didn't perform that trick of draining a little oil out the bottom, and pouring it back over teh governor, and it showed when I had to replace the governor. Tons of play in it. And considering it ran a sawmill most of it's life, the governor was worked quite a bit.
I never thought of using STP on my rockers though. I just used SAE 30 in a squirt oil can. Thanks for the tip!
Nedd
09-29-2005 09:08:21
 Re: overhead oiling in reply to Brian in Ohio, 09-28-2005 19:53:34
I was thinking of using some oil cups thru holes drilled thru the valve cover. It sounds like risky business tapping a oil line off of the mains. My 2 cents worth.
casenut
09-29-2005 12:49:08
 Re: overhead oiling in reply to Nedd, 09-29-2005 09:08:21
one more input on my 1929 L Case gave a fitting that protruded through the hood from the valve cover. The oil ran into a tray above the rocker arms and also had some felt in the tray to hold some of the oil buth then dripped onto the rocker arms. I believe this was the oly year that was used.
L.C.Grey
09-29-2005 20:15:59
 Re: overhead oiling in reply to casenut, 09-29-2005 12:49:08
My '29 L has the hole in the hood for valve train oiling, but best I can tell it has had an LA head and valve cover put on it. The top of the valve cover is smooth. I read somewhere the 29's had a lot of trouble cracking heads and the castings were later improved to prevent it.
The oil lines on mine run externally to the head and governor just like a production LA. The oil filter is in the same place as an LA but the return line is plumbed into the lower left rear corner of the block as if it actually goes into the clutch housing. I'm sure they didn't change the whole engine though as the block number matches the chassis number and theres no starter hole in it. The aluminum "Luberfiner" filter couldn't have been put on before 1937 as thats the year Luberfiner went into busines. I imagine the top end and governor oiling were added at the same time it was being retrofitted with the filter.
I'm told that Ls could be ordered with top end oiling, but greatly doubt that any of the 29's were equipped with it.
