54 case sc pics of rear with eagle hitch
chris gaston
09-27-2005 16:27:15
i have a 54 sc but i think there are some things missing on the rear of the tractor it has an eagle hitch it seems as if the top link mount is missing and the only pics i can find are earlier models thanks
Camboted
09-28-2005 08:28:42
 Re: 54 case sc pics of rear with eagle hitch in reply to chris gaston, 09-27-2005 16:27:15
third party image
This is a DC but they are the same regarding the hitch. John Saeli has all the parts you are searching for including original top links. 1-315-585-9826 or [email protected]
JGarner
09-28-2005 07:57:10
Wish I had a picture to send, but the 53/54 had 2 top link mounting points. One under the seat and high and the other was a cast piece that bolts onto 4 studs that come out of the PTO housing on 4 corners. The piece has the mounting point on it as the top link turnbuckle mount end straddles the mounting point and a pin slips through the one side of the top link end, through the mount point hole and out the top link turnbuckle end on the other side. Do you have the top link? If its a factory link see if you can find a mount up high under the seat the the end will straddle. I am betting the PTO cover casting is missing. The top mount is used when hooked to PTO driven devices. For plow, disk, etc the lower mount is used to be able to properly adjust the angle of the implement.
