Case 741C
PUTTER
09-27-2005 07:38:55
I took alook at this tractor yesterday, it's up for bids near here. Was used to mow grass at an airport. I don't see this model listed in the serial number s section. Model 741C, serial number 8247479. It's a four cylinder gas. What year was it built, were they any good, what's the value? Guy that used it said it needed an engine overhaul. Looked to be in pretty rough shape but the tin was all there. Thanks PUTTER
segrat1
10-11-2005 20:09:48
 Re: Case 741C in reply to PUTTER, 09-27-2005 07:38:55
That tractor is"nt in bad shape. You forgot to mention it comes with a loader and 6"Woods ditch brush hog. Oh ya, I bought it! See ya at work.
Patrick (Mich.)
09-28-2005 21:03:09
Hey Putter, where are you located? I'm just wondering if I know the tractor in question, as a similar one is being used at an airport about 45 miles from me.
.Roger H
09-27-2005 07:55:22
That is a '64 730 Comfort King equipped with the Case O Matic transmission. There is a '62 830 LP here that has finally had an overhaul 6 years ago after 40 years of use. They are a very easy engine to rebuild, I have 3 930's that I rebuilt the engines on 2 of them & also an 800 combine that has the same as a 730 engine that has also been rebuilt, the combine sat for 20 years before I got it back so it was stuck tight.
PUTTER
09-27-2005 20:05:07
 Re: Case 741C in reply to .Roger H, 09-27-2005 07:55:22
Thanks for the info!!!!! !
