Removing a 530 steering wheel
BKahler
09-23-2005 06:11:24
I need to replace the manual steering pump seals and as such I need to remove the steering wheel. As is typical its stuck on there. The problem however is the throttle lever is in the way of getting a puller seated properly under the steering wheel.
Any suggestions on how to remove the steering wheel?
Thanks,
Brad
Phil (NJ,Az,Sask)
09-25-2005 05:41:54
 Re: Removing a 530 steering wheel in reply to BKahler, 09-23-2005 06:11:24
Brad, When I removed mine I think I just put the Nut Flush with Shaft End & while appying upward pressure (one Hand) Hit the Shaft end with a Big Hammer.. Jumped OFF
Hope This Helps,
BKahler
09-25-2005 15:51:01
 Re: Removing a 530 steering wheel in reply to Phil (NJ,Az,Sask), 09-25-2005 05:41:54
Phil,
I ended up trying something similar to what you suggested, pry bar underneath and a couple of light wacks with a hammer on the shaft and it popped free.
Thanks!
Brad
