any 2590 case opinions
jvks
09-22-2005 19:21:21
currently farm with a 1370 case tractor with who knows how many hours, regardless has been a very dependable workhorse. I plan to upgrade to a 2590 case if opinions lean toward favorable I would like to know how other users feel about this tractor.
Can't even use my name
09-23-2005 05:35:20
 Re: any 2590 case opinions in reply to jvks, 09-22-2005 19:21:21
Go for it. The 90's had a world better cab over the 70's. A 2590 will pull anything you could expect a 2wd to pull and then some. Start so easy and are much quieter than the 70's. We have a 2390 and I try to run it at 1700 rpms whenever possible and I can pull a 20' no-till drill and only use 0.4 gallons of fuel per acre doing about 10-15 acres per hour depending on field. And I love that flip up hood. Again, go for it.
South Texas Case
09-22-2005 20:48:34
I just got off a 1981 model with nearly 8000 hrs on it. It's been pulling an 8 row ripper-bedder all day. I also have a 1980 model with about the same hours. We have owned both since new and I put 75% of the hours on both. I haven't done anything to the engine in either one. Put power shift clutches in the '81 at 6000 hrs and the '80 had some rearend work while under warranty. When the dealer delivered them they dyno'ed 210 & 215 hp. One replaced a 1370 the other a 2390. They are every bit as good as any 1370 with a little better cab and alot more power. My personal opinion is they are one of best tractors of this size made by any company at any time. GOOD LUCK Tony
