VAC Hitch
scott vaughan
09-22-2005 18:45:54
Does anyone have a 3 pt. hitch for sale. Or does anyone have messurments so as to be able to make on. Thank you, scott
WALTER
09-23-2005 11:56:04
 Re: VAC Hitch in reply to scott vaughan, 09-22-2005 18:45:54
THE 3 POINT HITCH YOU ARE LOOKING AT IS FROM A WD ALLIS CHAMBERS. THE ROCK SHAFT IS GOOD ENUFF. ARE YOU LOOKING FOR A HITCH THAT IS ALL READY TOGETHER. IF SO I HAVE ONE FOR SALE. 300.00 IT IS ON MY VAC 1946. EMAIL ME AT [email protected]. NICE JOB GUY'S ON YOUR 3 POINT.
mj
09-23-2005 06:49:44
third party image
Here are some hitches on early VA tractors.....the one shown is on a "48. Click the link for more and then click an image to enlarge.
Bret4207
09-23-2005 09:54:30
 Re: VAC Hitch in reply to mj, 09-23-2005 06:49:44
I've got the same setup as your 46 VAC. I built a top link mount that comes off the top cover and hung 2 draft arms on the 2-way plow mounts. I also had to go to a log splitter control valve when my original high pressure valve bit the dust. Works OK and will lift more than my 800 Ford, but light in the front end and you have to use chains to control the sway. Pretty hard tobeat a VA series for a small chore tractor.
mj
09-23-2005 06:42:11
third party image
scott vaughan
09-22-2005 18:47:47
Oh its a 47 VAC.
