LA rims
Engineer20
09-22-2005 07:50:51
Hi all,
I'm going to be needing new front rims for sure and probably will replace the rear ones too. I see that Miller Tire sells new rims. Can anyone tell me if the ones Miller sells will work on my LA? Can anyone tell me the correct sizes of the front and rear rims for an LA? I think the diameters are 18" and 30" but not sure on the widths. Thanks for your help!
StuckRusty
09-24-2005 07:04:28
 Re: LA rims in reply to Engineer20, 09-22-2005 07:50:51
I needed a front rim for my LA and I got one from a junk Farmall W9. I did have to torch off a metal tab used to keep the rim from spinning on the hub.
Fred in Ut
09-22-2005 08:13:08
According to J.I Case LA tractor data, found on the link attached to this fine web page, the front tires are 7.50-18 and the rear tires are 15-30. Good luck. I am going tomorrow to buy an LA for restoration. The tractor is in bad shape. I hope this city boy can do it!
Engineer20
09-23-2005 06:37:44
 Re: LA rims in reply to Fred in Ut, 09-22-2005 08:13:08
Fred,
I know that's the tire size but is that the acutual rim size too?
AllanC
09-22-2005 21:40:22
LA front rims are fairly standard rims. They are used on some massey harris too.
