800 tractor crankshaft
glr62
09-21-2005 18:00:20
Were the 800 crankshafts in the diesels case hardened? Is grinding rods and mains any problem? Heard of broken cranks after grinding, but don't know what models.
c hess
09-21-2005 19:30:31
 Re: 800 tractor crankshaft in reply to glr62, 09-21-2005 18:00:20
Diesel cranks are induction hardned. I have always heard you can grind 10thousants off but more is risky Ihave a830 that had 10thousants off of throws many yrs ago - no problem
charley hellickson
09-21-2005 19:25:50
grinding that little amount off of a crankshaft isn't going to make it break.something else made it break.
buckmaster 700
09-24-2005 10:53:12
 Re: 800 tractor crankshaft in reply to charley hellickson, 09-21-2005 19:25:50
the old 830 would break if the ballance shaft was not timed right at the time of rebuild .the 800 267 diesel wont have that problem it has no ballance shaft. if you pull the pan and it dose have a balance shaft someone swapped in a 301
