Hydralic fluid for 51 case
Louis
09-20-2005 00:27:06
can anyone tell me where you find the hydralic fluid fill hole for the 51 VAC? I am leaking oil from the implement hoses and have to refill, but do not know where or how?
Thanks
Cases n Harleys
09-20-2005 15:17:55
 Re: Hydralic fluid for 51 case in reply to Louis, 09-20-2005 00:27:06
You'll find the hyd fill hole plug on the left side of your torque tube just below the steering gear box, basically straight across from the flat belt pulley. Just fill it to the bottom of the plug hole. originally I believe sae 30 motor oil was used for the hydraulics.(torque tube runs from bell housing to transmission). keep plenty of fluid in it, it also lubricates 2 tapered support bearings inside the torque tube.
