CASE SC manual questions
OldIron
09-19-2005 18:42:57
Hello
I have a 1951 Case SC, s # 5525791 SC.
I have several questions.
First, what is an Eagle Hitch? How do I know if mine has one? Any photos to identify it?
Second, how do I determine what is the correct shop/owners manuals for my tractor? I don;t wan tto order the wrong manuals for it to find I spent money wastefully.
Third: What"s the Magneto timing gap for my tractor? ( I want to buy the manual, but in the mean-time...)
Thanks for the patience with a new Case owner. I own 2 Massey Harris, a newer Ford 3400, and an Allis WD-45.
OLDIRON
RandyN (MO)
09-20-2005 16:04:56
 Re: CASE SC manual questions in reply to OldIron, 09-19-2005 18:42:57
Hi Oldiron,
Eagle Hitch was Case's answer to the three point hitch. It strongly resembles a common three point hitch but the arms are rigid, that is they don't swing from side to side like on a Ford 8N. The eyelets at the end of the arms aren't complete holes, either. You pull up a latch and the "hole" slides forward, lift the arms onto the implement until the pins are in the "holes", then pull forward and they latch close, then connect the top link. I don't have a picture to post, but I'm sure you can find a picture of an Eagle Hitch on this website if you look hard enough. The Eagle Hitch on my tractor works with an external hydraulic cylinder...don't know if they are all like that or not. Before the Eagle Hitch, Case had what was called a motor lift with two fixed arms that are much shorter than the Eagle Hitch arms and with two holes at the end for connection. Dad's DC had that and there was pedal you stepped on and the motor lift was either up or down...no in between.
I have a '52 SC (with Eagle Hitch!) and I have the Service Manual. As Todd said, the first part talks about all of the SC's, then there is an addendum that talks about the Eagle Hitch and live PTO, etc., that started later.
I'm not at home, so I can't look in the manual to see what it says about the magneto setting. I have an idea but I don't want to say "I think it's.." then it be wrong.
Good luck!
RandyN (MO)
OldIron
09-20-2005 12:02:37
 Re: CASE SC manual questions in reply to todd hamilton, 09-20-2005 06:47:47
Thanks
Does that manual have the point setting for the Magneto?
RD
todd hamilton
09-21-2005 05:03:30
 Re: CASE SC manual questions in reply to OldIron, 09-20-2005 12:02:37
Timing drive slot on mag drive is 25 degrees (two teeth) below horizontal (approx 8:00, rotates counter-clockwise) with #1 piston TDC. Look for 3/16" hole in flywheel just above the stamped (on flywheel) letter D to align with inspection hole.
Point gap is .011 - .020 with .015 recommended. My tractor has the distributor modification and runs better if the points are set a little wide at about .018.
