replace lower rad, hose sc
rd/oh
09-19-2005 16:51:06
trying to replace the lower rad. hose on a '52 sc with eagle hitch. I removed the nose and found a casting that was cast to fit in frame casting. I see no bolts to remove. How do I get it out? My '47 sc doesn't have that casting thanks. bty the '52 has cast front wheels
fredct
09-21-2005 18:50:43
 Re: replace lower rad, hose sc in reply to rd/oh, 09-19-2005 16:51:06
I believe what you are refering to is just a weight that sits in the front casting - gravity was/is doing the job in my two SCs. Fredct
rd/oh
09-24-2005 16:14:06
 Re: replace lower rad, hose sc in reply to fredct, 09-21-2005 18:50:43
Fredct thanks for the response and you are right . With an engine lift it came right out Thanks
