david brown selectomatic 990 differential lock
chuckster
09-19-2005 14:45:17
can anyone help me ? my 990 bd differential lock is in the lock position but only one wheel turns .pedal will not spring back up neither.winters coming sure would be nice to get it working again
baz
09-21-2005 23:41:53
 Re: david brown selectomatic 990 differential lock in reply to chuckster, 09-19-2005 14:45:17
If the pedal is down on the floor plate, the external lever the pedal pushes on to will have lifted up. If the external lever is stuck in engaged position, the pedal should be free to lift up and down. The pedal is either seized on its shaft, or maybe got wedged on the top of the external lever. Make sure the pedal is under the external lever. The external lever could also have the key between it and the shaft into the diff housing. If the external parts look OK you will have to remove the final drive and sort the inside inner parts. Barry.
