Vai Case Tractor
sirartisan
09-19-2005 14:07:19
I am wondering if vac tin work is exactly the same as a vac or is there a difference. For example where the steering runs through the grill of a vac that is not need on the vai.
Thanks guys
charley hellickson
09-20-2005 00:50:28
 Re: Vai Case Tractor in reply to sirartisan, 09-19-2005 14:07:19
i have both. there are the same except for two things.VAI does not have the steering cut out and on the upper part of grii side pannel it has holes for head lights.VAI was only one with lights mounted on side of grill to the rear of grill bars.sheet metal and dash are the same until they changed the steering on later ones. my vai is 1951.
CK RICHARD
09-19-2005 17:19:35
VA and VAI have a grill with out the cut out for the steering rod but it will fit.
Sir Artisan
09-20-2005 08:36:08
 Re: Vai Case Tractor in reply to CK RICHARD, 09-19-2005 17:19:35
I guess my next question to the forum would be does anyone have a vai case grill. I also need side panels. Secondly it looks to me as if the fenders have a different base from the vac.
Thanks Guys.
charley hellickson
09-21-2005 19:56:43
 Re: Vai Case Tractor in reply to Sir Artisan, 09-20-2005 08:36:08
sorry i told you a little wrong on the fenders. i looked again today.the other guy was trying to tell you right but i didn't get it but i got it know.the fender itself,the sheet metal,is the same.the mounting bracket on the bottom is diff- irent in height.the vai is flat,bottom of fender sits on axle housing.vac raises up 3 inches.vai has a flat iron across bottom of fender.vac looks like an angle iron on bottom of flat iron.they bolt on the same way.vac will work fine.
charley hellickson
09-21-2005 19:26:34
charley hellickson
09-21-2005 19:18:58
charley hellickson
09-20-2005 23:41:01
i went out and looked again for you and i got fooled.vai and vac fenders are exactley the same. the base of them and the mounting are the same.vac fenders will mount right on a vai. the difference is in the height.i thought they were the same.vai are 20 inches tall.vac are 24 inches tall with 28 inch tires.i don't know about 34 inch tires.you must have a vai that needs a lot of sheet metal.what year?my vac is 1950.good luck.
Jerry W
09-20-2005 11:02:08
My thought on the fenders is that the height of the base varies with the height of the tires. This is for sure on the VAC's with 28" rubber vs the VAC's with 34" rubber. I do not know if the VA and VAI's with 24" rubber are shorter yet or not.
Jerry
