CASE 1030 Steering problems
B Johnson
09-18-2005 15:16:52
I've got a 1030 Case and need to replace worn "tie rod ends". They're worn and the front wheels kind of wonder where they wish. Question..... One end of the "tie rod end" screws into the the "drag link" and the other end appears to press in/upwards. Is that correct? Does it press in? Do I need to press it out or just heat it up and beat it out? I'm trying not to break anything but it didn't seem to want to come out easily when I smacked it a couple of times. Does anyone have experience in removing/changing these out? OR should I just take it to the local shop and pay them?
Thanks much.
CNESLER
09-18-2005 16:03:06
 Re: CASE 1030 Steering problems in reply to B Johnson, 09-18-2005 15:16:52
The tie rods are tapered and go up through the bottom. Use a tie rod tool or wedge and tap the side of the arm that it's connected too. I just replaced some that just fell out.
Good Luck
CNESLER
