generator brushes
holcombwa
09-18-2005 08:17:03
I've been reading posts about the adjustable third brush on the old three brush (cutout type regulated through the light switch) generators. I have a Case VAO that has an autolite generator with three brushes in it. I thought by adjustable brush people were talking about adjusting the field terminal and hence the charge rate by way of the light switch. BUT, John T mentioned he would set the adjustable third brush at maximum charge when going to a three or four wire voltage regulator from a simple cutout type. Now I'm confused.
Our generator was getting so hot you couldn't touch it if the light switch was pulled out to any of the charge settings. That had been going on for the last couple seasons at least. We trickle charged the batteries all the time. I took the generator apart, cleaned all the terminals, carefully taped up bare wires, cleaned the copper part of the armature shinny with crocus cloth, blew out a lot of old dust dirt etc. and put it all back together. Oh, checked the bearings too as thought that might be the cause, but they seemed fine. Did the polarizing thing and fired tractor up with light switch out to high charge. Nothing. In a minute or less smoke was coming out from under the brush cover. The field insulation was on fire. What happened? Was it a fire waiting to happen and I speeded it along by improving the electrical connections (freshened up the battery terminals/cables too as well as the ground on the tractor)? Was pretty careful labeling things in the tear down and reinstall so don't think I got any wire to the wrong place. Finally, could I have inadvertantly done something wrong to the mysterious adjustable brush? (which one is that? I have two thick brushes: one grounded, one going to the field windings and on to the terminal, and one thin brush going to the cutout relay post. None seems to be adjustable in their mounting in any way). All help is appreciated. Sorry for the length of the post.
Stan
John T
09-18-2005 18:39:57
 Re: generator brushes in reply to holcombwa, 09-18-2005 08:17:03
Holcom, Im thinkin Bob is on to something n heres why !!!!! It would be my best guess, without seeing the generator, that the two larger brushes would be the Armature connection and Ground, as they carry the heaviest current (10 to 20 amps), while the Field current is far less current (maybe a few amps) so I would suspect its that lil thinner brush. On most Ive seen the Armature n grounded brushes are 180 opposite from each other while the third Field current brush is the offset one which connects to the first Field winding. The armature brush thats 180 opposite from the grunded brush wires to the Gens Armature post. Then on 3 brush generators the first field winding wires to the 3rd brush then to the second field then out to the Gens Field post.
Usually there are 2 or 3 screws you loosen which allows you to rotate that third adjustable brush closer to the armature brush for max charge or farther from it for less charge.
The reason I suggest setting them for max charge when converting from a cutout relay to a Voltage Regulator is cuz the VR has more sophisticated relays to regulate field current beter then the simple low or high charge when using light switches.
Let us know
John T
holcombwa
09-20-2005 07:22:27
 Re: generator brushes in reply to John T, 09-18-2005 18:39:57
Reconnected everything and double checked wires not toching anything they shouldn't be etc. Hooked it up and fired up tractor and generator gets so hot can't touch it. However, only gets hot when the light switch is pulled out to charge. Don't know if that is progress or not. Think I'll unhook the wiring and use it as a belt tensioner, and recharge with the trickle charger in the barn. Was going to use generator off my Farmall (have extra) but would block carb adjust screw. Thanks for the help
Stan
John T
09-20-2005 08:41:31
 Re: generator brushes in reply to holcombwa, 09-20-2005 07:22:27
To get that hot it sounds like you may be shorting out the armature. Its the Gens Field post, NOT the Armature that goes to the light switch to get a ground. I think I still think like Bob in that the Gens miswired or its brushes arent wire right internally????/
John T
holcombwa
09-21-2005 05:18:24
 Re: generator brushes in reply to John T, 09-20-2005 08:41:31
Field terminal hooked to the resistor on the light switch. Armature hooked to the Ammeter. Wire from the little brush going to the field post now. Wire from the big non-grounded brush going to the cutout and then on to the ammeter. Guessing there is an internal short somewhere. Trying to motor the generator produces nothing until the field terminal is grounded and then it spins slowly. But then on the two farmall generators I have they spun slowly when motored and only sped up to a somewhat normal speed when the field was grounded. I thought had read somewhere they were suppose to slow down when field was grounded so don't know. stan
Bob
09-18-2005 10:13:28
Sounds to me like you swapped the leads between the brush connected to the "cutout relay post" (A), and the other "field" (F) post.
