680 Case 301 BD Crank Intercahnge Question
Sonny Laufmann
09-16-2005 20:16:16
I bought a Case 680CK with loader not running - it is said to have a bad crankshaft.
Will the crankshaft from a Case Model 830 tractor with 301 engine fit in the BD engine??
How interchangeable are these two engines?? I have a complete 301 short block out of the 830.
Any information is appreciated - btw, the dealer says the 680CK should have a 336BD, but the tag on this engine clearly state 301BD - maybe this engine was only used in the 680 briefly at the start of the model run??
Thanks,
Sonny
WALTER
09-17-2005 10:52:43
 Re: 680 Case 301 BD Crank Intercahnge Question in reply to Sonny Laufmann, 09-16-2005 20:16:16
680CK HAS A 267 DEISEL. YOU CAN USE A 730 ENGINE FOR SURE.BECAUSE IT IS A 267 ALSO. THE 301 IS A Q: AS IT WOULD BOLT UP OR NOT. DEPEND'S WITHER THE TRAN'S HOOK UP WILL DO OR NOT.I WOULD TRY IT. AND SEE. BUT AS SRAIGHT BOLT UP. I WOULD TRY IT.
