SC point gap and rough running
Neal N
10-20-1999 04:28:54
I have a 45 Case SC with a Delco distributor. The manual I bought from the Case dealer shows only magnetos. I have been told the dist was a conversion. Anyone know what the point gap should be?
Now for the big problem. I was mowing awhile back and overheated the engine. I let it cool down for a few hours then added water and it started right up.It runs fine until you put a load on it then it acts like its running out of gas. I starts to die then picks back up then repeats the cycle. It didn't do this before the overheat so I checked the compression and all cylinders were around 105. I can't figure what could have changed as a result of overheating. FYI it has a new coil and plugs, points look good and battery is charged. Gas is fresh and appears to flow freely. Any ideas?
Neal
Jeremy
10-20-1999 10:15:24
 Re: SC point gap and rough running in reply to Neal N, 10-20-1999 04:28:54
The point gap is .020-.022" for a Delco-Remey distributer. As for the running rough problem, what kind of spark plug wires did you put on? If they are carbon or graphite core they won't work. Those old tractors only run with copper core plug wires. Another thing that it could be is that the ignition wires to the coil are reversed. Hope this helps.
Neal N
10-21-1999 04:03:11
 Re: Re: SC point gap and rough running in reply to Jeremy, 10-20-1999 10:15:24
Jeremy
We meet again. I'm the person who e-mailed you about your DC. Thanks for the info on the points. I haven't put plug wires on but will check them and the coil. At this point I'm stumped because it ran fine until it overheated and I can't figure out what would be related to overheating that would cause this problem. Also could you give me an address or phone # for MW.If I have to rebuild at some point I would be interested in the high compression pistons.
Thanks Again Neal
