VAC steering
jjohnston
09-15-2005 15:35:21
OOPS! The Vac is a 1946 narrow front.I greased the fittings I could see today,and took it for a ride and boy it is hard steering.It is a restored tractor and runs great.I think it hasen't been driven for a cupple of years.I need some help to get the steering a little easier.Thanks for all your help. Jim
mj
09-17-2005 08:11:42
 Re: VAC steering in reply to jjohnston, 09-15-2005 15:35:21
third party image
Your '46 probably has a 15 1/2 in. steering wheel..... ..if it does a change to the later 17 1/2 in. wheel will help. You can also add some length to the steering arm (at the front end of draglink) which will give the steering gear more mechanical advantage. Photo shows length added to a VAC adj. widefront arm which with a 17 1/2 in. wheel that resulted in a 'near power-steering' effect.
jimjohnstonj
09-17-2005 17:49:56
 Re: VAC steering in reply to mj, 09-17-2005 08:11:42
Thanks everyone for helping on my steering problem on my Vac.it is a lot better now.jj
Keith-OR
09-15-2005 21:57:33
look at this site, has the VAC manual. Will post the pages for the steering on VAC..HTH..Keith
Gary Cash
09-15-2005 22:39:21
 Re: VAC steering in reply to Keith-OR, 09-15-2005 21:57:33
Be sure and grease the zerks on your steering column. My steering had gotten tight and I was able to return it to "good" by properly greasing the steering column.
