Cyl Sleeve O-rings for a VAC 124 Eng.
Steve_Md
09-15-2005 06:53:03
Does anyone know the O-ring diameter and cross section for the Case VAC cylinder sleeves? Do you know if an O-ring set is available for purchase separately?
WALTER
09-16-2005 14:02:48
 Re: Cyl Sleeve O-rings for a VAC 124 Eng. in reply to Steve_Md, 09-15-2005 06:53:03
SIR,
YOU CAN GET NEW O-RING'S AT ANY CASE DEALER. THE PART NUMBER YOU REQUIRE IS BIN:FL44099D1011 PART:G46909
YOU WILL NEED 8 PACK'S TO O-RING THE HOLE ENGINE.THERE ARE 3 TO 8 DAY WAITE ON PART'S .
TomVAC
09-15-2005 18:23:43
Steve, i overhauled a VAC this spring and got o-rings from a parts store. I took a sleeve in and picked ones that fit the best and were close to originals. Sorry i can"t recall size.
george md
09-15-2005 12:41:25
Steve, If you have an old one , I can match it for you . I checked my catalogs and can't do the cross reference , But I do have what would be the ID of the oring .
george
