Case VC with starter problems
Jim on the left
10-19-1999 23:49:58
I just bought a 1941 Case VC and I can't figure out why the starter is not working. I replaced the battery with a new 6 volt, but I do have to admit that I have heard that this tractor is positively grounded. Does this mean that the positive terminal cable connector on the battery go directly to ground or should the positive terminal cable connect directly to the starter? I have tried connecting the battery both ways and still I am not even getting the starter to crank once. What can i do to find out what the problem is?
C. Amick
10-20-1999 10:22:26
 Re: Case VC with starter problems in reply to Jim on the left coast, 10-19-1999 23:49:58
The positive battery cable grounds directly to the tractor. Do you have the spring loaded push type starter button? The button may not be making contact. Does your starter have a remote mounted solenoid? Could the starter be stuck?
10-20-1999 20:26:32
 Re: Re: Case VC with starter problems in reply to C. Amick, 10-20-1999 10:22:26
I have a spring loaded push type starter button. So the cable that connects to the positive post on the battery should directly ground to the tractor and the cable connected to the negative post on the battery should connect to the back of the starter button. I have followed the cable from the starter button and it directly connects to the starter. I do not believe that there is a remote solenoid. Is there a way to connect jumper cables from the battery directly to the starter to see if the starter is locked up? How do I determine if the starter button is not making contact? Thanks for all your inputs!
