DC weight
SCpuller
09-14-2005 07:24:22
What would a dc weigh with pressed steel wheels front and rear? NO mechanical lift, no hydraulics or generator. Will it make 4500 lbs?
Doug Boll
09-16-2005 15:03:12
 Re: DC weight in reply to SCpuller, 09-14-2005 07:24:22
I can sometimes run 100# of weight in the 4000# class, thats on a Cc with light pan, gooseneck, eagle rear cover, round spoke fronts, cutoff rears 15.5x38 tires, weight brackets, battery and starter, depends on the scale and if they allow some tolerance, makes for some fun 2nd gear passes if there is no speed limit! A guy ran a DC at Madison, MN last week with cast rears, adj. front, and extra weight! (no scale at track) I pulled the same setup for years, base weight with me on it is around 4900!
Jim M
09-15-2005 17:34:19
Use a DI or DE radiator, a late model pressed steel valve cover, remove oil filter, replace rear traany cover with a plain cover with the eagle on it and you'll weigh even less.
dctom
09-14-2005 08:50:59
yes, no fenders either, mine weighed in at 3960 with out me on it tom
SCpuller
09-14-2005 10:13:14
 Re: DC weight in reply to dctom, 09-14-2005 08:50:59
Thanks
