Case 870
Doug Illum
09-13-2005 13:56:58
could any one tell me what a case 870 with a case-O-matic trans is worth I have spun a rod bearing and I am wonderin if it worth fixing or should I just junk it out
bigJ
09-13-2005 18:01:42
 Re: Case 870 in reply to Doug Illum, 09-13-2005 13:56:58
Where are you located? I may be interested in it.
jim handke
09-13-2005 14:02:10
870"s never had a case-o-matic. Are you talking about a powershift, or do you have a 830?
Doug Illum
09-13-2005 14:12:08
 Re: Case 870 in reply to jim handke, 09-13-2005 14:02:10
I was told by the orignal owner that it was a case-o-matic I am not sure now I know that it is not a power shift and it is a 870 for sure
Can't even use my name
09-13-2005 14:56:26
 Re: Case 870 in reply to Doug Illum, 09-13-2005 14:12:08
70 series were either powershift with 4 range gears on one lever and three forward gears plus reverse on another lever. The only other option was a 4 speed tranny with high and low range. A Case-O-Matic is a torque converter driven tranny like an automatic, put it in gear and hit the throttle and if the load is too big she just won't move and the engine won't rev up but it won't stall like a standard manual tranny would when you let out on the clutch. So what do ya have?
doug boll
09-13-2005 15:48:21
 Re: Case 870 in reply to Can't even use my name, 09-13-2005 14:56:26
even just a patch job won't be cheap- labor, parts, machine work ect. could easily spend $2500.00, if you don't fix it keep me in mind, might be interested as is
xiafarmkid
09-13-2005 16:43:38
 Re: Case 870 in reply to doug boll, 09-13-2005 15:48:21
Could you post a picture of your tractor? It would make it much easier for us to help you. Although the 870 essentially replaced the 830, there are huge differences between the two tractors. And so far from what you've described, the tractor doesn't fit the description of an 870.
Mikey
09-13-2005 18:50:11
 Re: Case 870 in reply to xiafarmkid, 09-13-2005 16:43:38
An 830 will have a flat, horizontal hood with the headlights in front above the grill.
An 870 will have a sloping hood with the headlights mounted in the rear fenders.
Doug Illum
09-14-2005 08:19:53
 Re: Case 870 in reply to Mikey, 09-13-2005 18:50:11
the tractor is a 870 the headlights are in the fenders and the hood slopes toward the front. still dont know what this thing is worth. All the metal is in great shape the tires are new but the seat needs repair. I have pulled the motor out and I have the parts to fix it but I still dont know if its worth sending the crank and block to the machine shop and I guess it has a power shift trans in it. It has one lever with four speeds and the other lever has three foward and one reverse.
09-14-2005 18:39:51
 Re: Case 870 in reply to Doug Illum, 09-14-2005 08:19:53
You have the powershift tranny then. I would guess it is worth about $5000 if all is good including the engine.
Mikey
09-14-2005 20:06:39
 Re: Case 870 in reply to Can't even use my name, 09-14-2005 18:39:51
With good metal and new tires, you have a GREAT tractor that's worth restoring. How many hours are on the tach? (was the tach replaced, mine was but it's a one owner, so I kept the old tach!)
Also, is the paint on the hood Desert Sunset (yellow) or white?
Also, can you post the sereal number? Then we can tell you how old it is.
case 930
09-15-2005 14:36:52
 Re: Case 870 in reply to Mikey, 09-14-2005 20:06:39
Hi I bought a 870 with cab and front end loder Desert sunset with a 8 speed last week for 3100 It had a rubild on the moter by case last wenter he siad it cost 4000 to get that done Thanks Nick in AR
