Case 900 Power Steering hose configuration
Iowa Rick T
09-13-2005 11:47:56
Can anyone answer me how the power steering hoses are configured on a Case 900? My tractor was missing pump and hoses when purchased and I have located and added a pump, but now am scratching my bald head over how the hoses should attach. I measured about 19 inches distance from pump to cylinder on the high pressure hose side and 22 inches on the return, but the Case parts manual states that the hoses are 30 inces in length! Does this mean that the hoses lay down along the clyinder? Do the hoses have straight ends or 90 degree bends where they attach to the cylinder?
A picture is worth a thousand words and if someone could give me a jpeg of the hose setup, it should make things clearer!
Thanks! Rick
09-14-2005 06:11:08
 Thanks! in reply to Iowa Rick T, 09-13-2005 11:47:56
Thanks for the responses. I appreciate the help.
Camboted
09-14-2005 04:25:30
 Re: Case 900 Power Steering hose configuration in reply to Iowa Rick T, 09-13-2005 11:47:56
third party image
Here you are. The larger diameter hose going up is the return line.
caseman-d
09-13-2005 20:57:25
Send me a email to [email protected] and I will send you some pictures. I have all my books packed away as I will be moving next month. caseman-d
