Kent, I have seen too many 6 volt batteries EXPLODE when jumped direct at the battery with a 12 volt battery source, so I cant recommend it. However, in tractors with electric starter solenoids where its possible to ONLY jump the starter terminal (i.e. the starter side of the solenoid or direct to starter post itself) I have successfully and safely jumped many 6 volt tractors with 12 volt batteries. When you do that the starter is the only thing that sees the 12 volts so its safer for the rest of the tractor. NOTE OF CAUTION: Some tractors are Positive ground, so/but you still jump + to + and - to - remember between the 2 batteries. If your jump source say a truck battery is - ground and the tractors is positive ground, dont get the truck bumper in contact with the tractors iron frame when youre doing all of this. The MOST DANGEROUS SCENARIO is to attach jumper cables from a 12 volt battery right there on the 6 volt battery itself cuz thats where the escaping hydrogen gas is most present. Its less dangerous if you make the final frame ground jumper cable connection down on the side of the tractor far away from the battery and its escaping expolsive gasses. I say final frame ground connection cuz thats safer then trying to make the final jump connection say on the starter post or solenoid terminal. Sooooo oooo yes you can jump 12 to 6 but its most dangerous right on the battery top,,,,, (DONT RECOMMEND),,,,, ,,,less dangerous if the final jumped connection is down away from the battery on the frame somewhere,,,,, ,,,but most safe and recommended you jump ONLY THE STARTER where possible such as on electric solenoid type of starter switches. (so you only jump the starter itself) NOTE: On tractors with mechanical push start switches (not solenoids) you can still jump the Starter ONLY if you removed the big cable that leads to the 6 volt battery (so the 6 volt battery is out of the circuit) but you may likely have to jump/connect the lil wire on the starter switch to the removed big battery cable cuz thats often the main power feed for the lights n ignition etc. John T Nordhoff in Indiana, retired electrical engineer
