case farmall interchange?
holcombwa
09-12-2005 17:08:38
Just got done fixing up farmall A charging system. Cleaned up the generator on our Case VAO today (it had been hot every time we used tractor last two seasons at least) and after a couple minutes of running (without producing current on the anmeter) it was smoking. Windings had gotten hot enough to smoke. Sooo... has anyone put a farmall generator on a VA series? With the Case pulley on, it can be made to fit. Is there any reason not to do it from a safety or funtionality standpoint? All help is appreciated.
Stan
jal-SD
09-12-2005 19:38:33
 Re: case farmall interchange? in reply to holcombwa, 09-12-2005 17:08:38
If the old one is a delco, one from a farmall should work, I'd think, but then my thoughts & a nickle will get you a cup of coffee @ Wall Drug. (My $0.02 worth. jal-SD)
holcombwa
09-12-2005 20:01:52
 Re: case farmall interchange? in reply to jal-SD, 09-12-2005 19:38:33
Case is an autolite and farmall is a delco. don't know, but seems like a 6 volt generator is a 6 bolt generator and the two really are very similar. I don't think the case version I have is fixable so will have to come up with an alternative. Let me know if there is something important I'm missing in trying to swap em.
Stan
Camboted
09-12-2005 23:26:31
 Re: case farmall interchange? in reply to holcombwa, 09-12-2005 20:01:52
Yes, you can swap it but you need to check to see if you have a voltage regulator or the three stage contact on your current Case generator, basically, if you have the same number of wires out of both generators, then there should not be a problem. It would be a good idea to polarize the system when you get it hooked up.
Wayne J.
09-13-2005 05:27:26
 Re: case farmall interchange? in reply to Camboted, 09-12-2005 23:26:31
Hay guys I think ( IH ) is positive ground and 6 volt Case is negative ground. I think there was a discussion on that on the board a couple of days ago. check the polarity or you may let the smoke out of somethink else. keep it 6 volt GOOD LUCK Wayne J.
Keith-OR
09-13-2005 07:29:24
 Re: case farmall interchange? in reply to Wayne J., 09-13-2005 05:27:26
third party image
Hey Wayne, both are 6 volt pos. ground..Here is a wiring diagram of Case VA...Keith
holcombwa
09-13-2005 20:24:09
 Re: case farmall interchange? in reply to Keith-OR, 09-13-2005 07:29:24
Thanks for the diagram Keith. The case has a cutout and the farmall had a 4 prong relay, but that was added later. It originally had a cutout and control of the charging was through the light swith like the Case. I'll give it a try later this week and see what happens. Thanks to everyone.
Stan
