Case C, questions, year, need parts
Robert Hartsoe
09-11-2005 18:48:55
I just bought a Case C and cannot figure out the year and I also need some parts.
There is a casting number on the block behind the Magneto which is very hard to read. I think it is 4569A or possibly the A is a 4. The serial # plate is missing from the tool box. I would like to identify the year if possible. There is a casting number on the trans. housing of A4600A and a number on the rear wheel of 5232A
I need an exhaust manifold and intake manifold. Also the carb leaks at the bottom valve outlet. It will not tighten enough to stop the leak. I assume I probably need a carb or a rebuild kit?
I also need a set of fenders. The engine runs great and trans and clutch seem good.
Question, do all the years of the C have the same manifolds, fenders? Carb?
Is there any other specific way of identifying the year?
I appreciate any help I can get.
Robert Hartsoe
Brian in Ohio
09-12-2005 07:12:34
 Re: Case C, questions, year, need parts in reply to Robert Hartsoe, 09-11-2005 18:48:55
If you look on the mag side of the engine block, next to the fuel tank, and right where the head and block meet, you will find a small place that has been machined flat, and a number stamped into that square / rectangle. You should find the serial number there. It will beginwith "C" and a six digit number.
Take the first and fourth digit, put them together, and subtract three. (Example: C300916 39 - 3 = 36 1936)
