stuck engine
Travist
09-11-2005 17:18:16
I recently bought a 1944 Case SC. The engine is stuck. And I wondered if anyone had any ideas on how to free it up.
rick goodenough
09-14-2005 06:05:43
 Re: stuck engine in reply to Travist, 09-11-2005 17:18:16
make sure you either take the head off or push rods off.I have 41 SC that had stuck engine.put marvel and olive oil in cyl.when I tried to turn over,I bent the push rods.costly mistake...Rick G
Case1950
09-13-2005 19:27:11
This sounds crazy but works very well. Take all the spark plugs out of the engine. Take an old spark plug and hollow it out. Weld a hydraulic fitting to the spark plug. Attach a hydraulic line to the spark plug/fitting and connect to another tractor. When you apply hyd. pressure your engine will turn over. Make sure you pick a cylinder with both valves closed and the piston as close to the top as you can find.
Case1950
(Travis)
DJM75
09-13-2005 17:45:14
a couple of ideas I hear kerosene or diesel fuel works also atf and my favorite coke yes like the pop it will eat up a penny so why not free and engine. good luck
CNESLER
09-12-2005 14:51:50
I would start by pulling the spark plugs and
squirting oil into the cylinders, Let it soak
several days. Then try to rock the crank back and forth.
Good Luck
CNESLER
