Case DC hard to roll over
mike greco
09-11-2005 15:24:21
Hi, I am in need of advice. I have a 45 dc. It sat under a tarp for 4 years now with a new battery and cables it is hard to roll over. any advice please.
Camboted
09-11-2005 16:18:34
 Re: Case DC hard to roll over in reply to mike greco, 09-11-2005 15:24:21
Hard to roll over or stuck? If just hard to roll over, pull plugs pour in a cup of 1/2 motor oil & 1/2 diesel, marvel oil, or some type of solvent mixed with a little oil. Let it sit for an hour and try again. Also, you may want to pull the valve cover and see if the valves are loose. Lubricate the valve stems, LEAVE THE PLUGS OUT, and try again.
Also, make sure your battery connections are clean. You may have to pull the starter and clean the armature and brushes. LOL
Bob in Australia
09-11-2005 17:22:11
 Re: Case DC hard to roll over in reply to Camboted, 09-11-2005 16:18:34
I have had similar problems with a chain drive Case tractors being left to sit for a couple of years. As Ted indicated, check the valves. They are often stuck making it difficult to turn the motor over. Be patient and work at freeing them up. It takes levering, maybe gentle hammering and plenty of oil.
I once made the mistake of towing a C and had to buy a pushrod from Don L as a result!
