Case 311 models
Garnet
09-11-2005 12:22:15
I belive I have a 311b round nose with adjustabe front axle.
I understand ther are three differant front ends to a 311. Can someone explain the differance in the model numbers?
Also can someone tell me if ther are after market fenders available?
Also can you tell me where to get a cream paint to approxemtly match the original?
Garnet
09-11-2005 21:50:07
 Case 311 model in reply to Garnet, 09-11-2005 12:22:15
Thank you so it seems I have a 311 general purpose gas with wide front end and generator w 6volt system. Thanks
I do have a uap and fsc near by so I will ask for paint for a 56 case 311 and see what they have. Thanks again.
I needs some work to get it running. I found a stearing box and a parts manual and all I need now is a service manual and I should have everything I need to get it runing again.
Any suggestions regarding conversion to 12 volt and altinator?
MWMCCA
09-26-2005 19:40:06
 Re: Case 311 model - 12 volt conversion in reply to Garnet, 09-11-2005 21:50:07
Garnet:
I know it is almost sac-religious to alter these gems, but a couple of years ago I converted my Case 311b from 6 volt to 12 volt w/ electronic ignition with kits readily available from Genesse Products. Supper-helpful gents.!
The systems work GREAT!
I have photos of my conversion if you need them.
John H-WI
09-11-2005 15:35:40
 Re: Case 311 models in reply to Garnet, 09-11-2005 12:22:15
Garnet, if you have a round nose its a 300. The "B" series were the square fronts with the eyebrow headlites.
The fronts were, single wheel, dual narrow wheels, wide fronts on both the general purpose and the utility version. 300, 310 were diesel and gas utilities, 301 and 311 were the general purpose diesel and gas. 302 and 312 were high clearance diesel and gas. The 320 is a industrial diesel.
Diesels are rather hard to find as not too many were sold. High clearance was also limited.
gary case
09-11-2005 14:57:40
garnet, don't know about the frontend,but the paint can be bought at napa but worth it. or you can get it at tsc stores. the fenders a ? but they might make and after market fender. try a shout out at camboted, he might know. good luck
