377 engine
my 600 diesel
09-11-2005 12:03:46
will 401 sleeves fit in 600diesel without boring the block? also will another starter starter fit out of something else?
Roger (Mi)
09-11-2005 18:08:04
 Re: 401 sleeves will NOT fit without block work? in reply to my 600 diesel, 09-11-2005 12:03:46
At one time, a company made oversize sleeves to fit into a 377 to make it a 401. I saw the sales book. When I called, the sleeves were no longer available. I have a 500 which could use a good overhaul, and those sleeves would have been ideal. Maybe someone knows another source?
caseman-d
09-13-2005 21:07:39
 Re: 401 sleeves will NOT fit without block work? in reply to Roger (Mi), 09-11-2005 18:08:04
standard piston, sleeves and rings are still available from case IH. I do think there is a difference depending on the block number. You may also might check and see what the 930 gas had as it was also a 377. I was also told one has to bore the 377 block for the 401 sleeves.
caseman-d
