Case VC Wiring Question
South Texas Cas
09-09-2005 21:05:07
Is a VC positive or negitive ground. Also on the generator which wire is which, the rear wire has yellow cloth insulation. The front has green insulation, but it is not cloth. I have the wire from the ammeter hooked to the bat terminal on the cutout. The green wire to the other cutout terminal and the yellow goes back to the light switch, a three position original type switch. Does this sound like I have it right. The generator has just been gone through at a electrical shop, so should be good, but the ammeter shows 10 amp discharge while running and a couple amp charge not running with ignition switch on. Does this mean the wires need to be swiched on the ammeter terminals. The battery is hooked up negitive ground right now. THANKS Tony
Keith-OR
09-10-2005 10:29:31
 Re: Case VC Wiring Question in reply to South Texas Case, 09-09-2005 21:05:07
third party image
Should be Positive ground. Here is the wiring diagram for your VAC..HTH..Keith
