What is the correct 2390 inj pump timing
Can't even use
09-08-2005 13:10:29
What is the best timing for a 2390 engine. I thought it was 27 degrees BTDC but on the valve cover it says the timing is 25 degrees BTDC. Which produces the most power, this fuel is getting expensive! And can you set at 1270 or 1370 to these settings. I think they are supposed to be at 29 degrees.
big orange
09-08-2005 16:57:48
 Re: What is the correct 2390 inj pump timing in reply to Can't even use my name, 09-08-2005 13:10:29
25 degrees is what the service manual says.27 is for the 2590's.The farther you advance to a point will make more power,also more smoke and heat.
09-08-2005 18:15:23
 Re: What is the correct 2390 inj pump timing in reply to big orange, 09-08-2005 16:57:48
I have a pyro installed post turbo so I can monitor the temps. So 25 degrees is factory for the 2390. I assume that advancing means further from TDC so 27 or 29 degrees would be advancing. Am I correct. Or am I backwards here.
big orange
09-08-2005 18:22:43
 Re: What is the correct 2390 inj pump timing in reply to Can't even use my name, 09-08-2005 18:15:23
That's correct,if I remember correctly my 1170 was 30 or 31 BTDC.Another advantage to 25 is that the engine starts better in the cold,the farther the advance the harder they start.
