Case Model 42--What's it worth?
Blue95
09-07-2005 20:04:54
I have a Case Model 42 with a buldozer in the front and a backhoe in the rear. She turns over, but does not start.
I need to get rid of it, and am wondering what it's worth in it's present state.
charley hellickson
09-09-2005 21:35:17
 Re: Case Model 42--What's it worth? in reply to Blue95, 09-07-2005 20:04:54
Hi Blue95. what state do you live in? i just want to know how far you are from Iowa. thanks. Charley.
Blue95
09-10-2005 00:33:36
 Re: Case Model 42--What's it worth? in reply to charley hellickson, 09-09-2005 21:35:17
I'm in Northern Illinois, about an hour west of Chicago.
Go Illini.
WALTER
09-08-2005 09:12:08
DO YOU HAVE A PICTURE OF IT TO SHOW. AND SERIAL NUMBER.
Blue95
09-08-2005 15:31:20
 Re: Case Model 42--What's it worth? in reply to WALTER, 09-08-2005 09:12:08
Good question
Pictures can be viewed at the enclosed link.
Serial Number: 4077407
3248.5 hours on the clock
It ran when parked about 5 years ago.
Triplerange
09-09-2005 10:44:38
 Re: Case Model 42--What's it worth? in reply to Blue95, 09-08-2005 15:31:20
That's a 420 (industrial 430). No idea what its worth. Is it gas or diesel? Shuttle shift? Does it turn over or is it stuck?
Blue95
09-10-2005 00:35:04
 Re: Case Model 42--What's it worth? in reply to Triplerange, 09-09-2005 10:44:38
Gas. What is shuttle shift? How do I tell if it has shuttle shift?
It turns over, just dosen't start.
charley hellickson
09-11-2005 22:48:33
 Re: Case Model 42--What's it worth? in reply to Blue95, 09-10-2005 00:35:04
it should have shuttle shift,it was used on con- stuction tractors with loaders so you could back up fast.should be a round lever with knob on end sticking up on left side of trany.push clutch and move forward or back,which ever direction you want to goe.no reverse gear in trany.shift lever on right side of trany is daul range,high & low.8 speedes forward and 8 reverse.staight line shifting back & forth.reverse gear was faster than forward.over 20 mph either way.
