Case 1070
Case400
09-06-2005 21:49:07
Anyone know what it takes to replace the ring and pinion in a 1070 power shift? Cost? Amount of time to do repair? How big of project is this going to be? (I want to do it myself)
I realize the tractor must be split to remove the pinon shaft, but how would I go about removing the bevel ring gear? Is it removed from the top, back, or rear of the tranny? Must I remove the cab and axels to get to it?
Grumpy
09-07-2005 19:30:46
 Re: Case 1070 in reply to Case400, 09-06-2005 21:49:07
split tractor at motor. remove powershift. remove pto housing. remove axel nuts. jack axels out. remove bull gears. remove brakes and housings. remove diff cross shaft. this takes a 30 ton portapower. roll diff out back. remove nuts on front of pinion shaft. will take 40 hours or more. don't do it without book. Stan
Case400
09-07-2005 21:25:16
 Re: Case 1070 in reply to Grumpy, 09-07-2005 19:30:46
So I should be able to leave cab and platform on tranny?
Tom (Ks)
09-08-2005 17:16:49
 Re: Case 1070 in reply to Case400, 09-07-2005 21:25:16
We left the cabs on and worked around them. You may have to remove the draft sensing shaft out of the rockshaft housing to roll the diff out the back.
