weight loss on SC
linkman
09-05-2005 17:34:38
I need to lose 700 lbs on my 1950 SC any ideas?
Jim Evans
09-05-2005 18:42:05
 Re: weight loss on SC in reply to linkman, 09-05-2005 17:34:38
How much are you starting with? Remove the front weight, replace the front cast wheels with stamped wheels, and replace the back cast wheels with cut-off spoke wheels from a former steel wheel tractor. Remove the cultivator lift, and you should easily remove 700 lbs. You could also remove the hydraulics and replace the entire rear cover with a steel plate.
Jim
