break seals on a DC HELP
36 A
09-05-2005 12:03:27
Went to put new seals and breaks on the break shafts on dads DC.we left the disks and drums off in case it leaked well it leaks.Dose any body have any referanse to the part numbers.The old seal #07041AB,new number on the bag is#61087092 and the number printed on the seal is28686. has any onelse had this happen .The new seal dosent even touch the shaft.Thanks
Paul f
09-06-2005 06:10:48
 Re: Seal numbers in reply to 36 A, 09-05-2005 12:03:27
If your O7041AB number is correct for your tractor the newer Case number should be A27130 which converts to CR 27368
Paul f
09-06-2005 06:19:44
 Re: Seal numbers in reply to Paul f, 09-06-2005 06:10:48
CR 27370 and national 417316 should also work
Paul f
09-06-2005 06:00:16
 Re: break seals on a DC HELP in reply to 36 A, 09-05-2005 12:03:27
The seal you have 28686 is a CR replacement for the outer shaft seal O3873AB (New # A26759) used on later DCs (Serial # 5600000 and after)
36 A
09-05-2005 19:53:43
Thanks guys Its a 51 .
Don O
09-05-2005 18:17:11
I had to take my old seal to the IH dealer to get the right one.
dctom
09-05-2005 16:36:17
the later tractors had bigger shafts than the earlier ones, sounds like you have seals for later DC's ask for 1950 or earlier tractors tom
