eagle hitch for my case sc/starter gear needed
Joel e. Shelton
09-05-2005 06:41:54
I was wondering if an eagle hitch assembly could be installed on my 1950 case sc. It has hydrilics installed but no two point lift or anything else for lifting. It does have a drawbar but I want to use some 3 point implements. What would I need to install the a complete eagle hitch and would the eagle hitch work with a 3 point plow or 3 point bush hog?
My second need is for the gear inside the starter that comes in contact with the flywheel. Recently I took my starter off and replaced the starter seal and reinstalled the starter. I placed the bolt in the correct spot and lined up and pushed in the starter all the way. Now all I get is a grinding and after several turns I see that the teeth on the starter gear are now starting to break off. Any suggestions that I may be missing on the starter reinstall?
Thanks for the help.
Joel
Joel shleton
09-07-2005 20:22:36
 Re: eagle hitch for my case sc/starter gear needed in reply to Joel e. Shelton, 09-05-2005 06:41:54
is there anyone that can help?
