Delco-Remy Distributor Rebuild Part numbers - HELP
Joel Dube
09-05-2005 04:03:21
Hi all,
Good morning.
Was out in the yard until 11:00pm last night trying to get spark in my old case. No luck. I think it maybe the points and condensor as I installed a new coil. I get 12 volt at both poles on the coil with the switch on. Could anyone provide me with the part numbers for the points and Condensor for my Delco-Remy 1111909 distributor. The local Auto Zone and other parts stores are open today, not NAPA though.
Also, any hints on troubleshooting would be greatly appreciated, I searched here a bunch and found some good help, some more would be great too.
Thank you very much in advance.
Sincerely,
Joel
Phil (NJ,AZ,Sask)
09-06-2005 16:53:23
 Re: Delco-Remy Distributor Rebuild Part numbers - in reply to Joel Dube, 09-05-2005 04:03:21
Joel,
[Quote]I get 12 volt at both poles on the coil with the switch on.
You need the points "closed" to measure anything
useful.
1. Switch ON, Points Closed, Dist Side of coil = Zero, Battery side of Coil = 12V
Hope This Helps
DJM75
09-06-2005 04:21:49
If you decide to stay with points you shouldn't have 12 volts at the coil there should be a sandstone resistor in the hot line from the switch to the coil or you will keep burning points. Good luck
Mark Sc
09-05-2005 06:45:58
Joel, You might want to give electronic ignition a try. Supposedly it will last for a very long time with no points to file. Fits in most of the Delco Remy distributors and uses the new coil you bought. We use one for pulling and it puts out quite a spark.
Good Luck,
Mark S
Paul f
09-05-2005 05:55:25
Joel Parts store usually have a ignition book...With the distributor model # they can find the #s you want. My parts store did it for my delco-remy
Delco-Remy Distibutor Mdl 1111411
Standard Igniton Part #
Points DR-2227XP
Condensor DR-60X
Rotor DR158
Cap DR-405
