930 Clutch?
Travis
09-04-2005 20:58:21
Hey all,
Got a 930 that I need to put a clutch in, won"t even pull itself. Any pointers that I should know?? I don"t split too many older tractors without the framerails and actually have never split a 930. Looks like it would be easier to just jack up the front half and roll the back half away?.
Thank you for any pointers.
Travis
jim handke
09-05-2005 09:33:56
 Re: 930 Clutch? in reply to Travis, 09-04-2005 20:58:21
We have a stand that sits under the oil pan with two bolts that raise and lower it as needed to level it. We use two splitting wedges to block the front axle. The rear is raised by a large floor jack and rolled back.
CNESLER
09-05-2005 05:30:34
Be sure to block the engine where it connects to the front axle so that it will not roll side to side and Im sure that others can come up with more suggestions
Good Luck and be careful
CNESLER
