case 430 piston stuck in cylinder, hydrostatic st
Scott Whalen
09-04-2005 14:59:54
Can anyone tell me how to get the piston out of the cylinder? I have already moved the snap ring in like the manual says. I have also removed both ball studs and associated hardware. It feels like metal to metal contact when I try to pull it out.
Thanks,
Scott
Tom (Ks)
09-04-2005 17:51:30
 Re: case 430 piston stuck in cylinder, hydrostati in reply to Scott Whalen, 09-04-2005 14:59:54
If you moved the snap ring to the deeper groove, it should come out. A friend of mine had a 430 and he took the steering cylinders to a machine shop. They cut off the ends of both cylinders and rebuilt them and then welded them back together. Thay didn't know thay could take them apart.
Scott Whalen
09-05-2005 11:41:31
 Re: case 430 piston stuck in cylinder, hydrostati in reply to Tom (Ks), 09-04-2005 17:51:30
The snap ring is in the smallest groove. Do you think the seal could be stopping the piston. Maybe that's why it's leaking. If I can't get it apart today I will take it to a Case dealer. Thanks for the info.
Scott
Tom (Ks)
09-05-2005 15:30:52
 Re: case 430 piston stuck in cylinder, hydrostati in reply to Scott Whalen, 09-05-2005 11:41:31
Move the snap ring into the deepest groove to remove. It should be wide and deep.
Scott Whalen
09-05-2005 19:43:54
 Re: case 430 piston stuck in cylinder, hydrostati in reply to Tom (Ks), 09-05-2005 15:30:52
It finally came out. The snap ring was in the right groove. The piston was catching on the edge of the cylinder where some paint had built up. After a couple of hard pulls it popped out.(Along with some yellow paint) Thanks for the info Tom,
Scott
