Case 930 Hyd
RIck Stanton
09-03-2005 20:11:59
last year I put washers under the relief valve so I would have more presure to lift my JD1240hydro swing it worked fine, even though my hyd. made a screaming noise and vibrated real bad. Well this year after cutting a field my pump seem to be loosing fluid from anyplace possible on the pump. Then the pump stopped working. I took it out and found the small metal piece that connects the two shafs to gether came lose somehow. now that I have the pump off can it be rebild and if so is their a kit? or do a have to look for O rings?
