would hy-trans fluid work in my VA?
Jason, NW Ontar
09-03-2005 05:08:06
I don't have a manual for my VA, so I'd like some opinions on what will work. If anyone has the manual to tell me, that would be appreciated as well.
Jerry W
09-04-2005 07:36:51
 Re: would hy-trans fluid work in my VA? in reply to Jason, NW Ontario, 09-03-2005 05:08:06
If you are talking about the hydraulic system, I am sure it would work but might be a bit expensive. The manual call for SAE 5w,10w,or 20w depending upon outside temperature.
I personally use used commercial air compressor oil from work that would otherwise get recyled. It probably is similiar to hytran. We change it once a year on 4 200hp rotary screw compressors. They each take 25 gallons and it is almost the same color when it is drained as when it is put in.
Jerry
