Geeeee ee, So many questions so little time lol, No problem Im glad to try n help but this is tough over the net not having the tractor in front of me. 1) If its working good n charging, lets leave it as is regardless of Pos or Neg ground for now at least. A Gen will work either way,,,,, ,some VR's will work either way some wont, but if yours is charging, lets not worry lol. If it has an ammeter and its wired correct, if you turn on lights or ignition when shes not running, it should swing over in the - discharge region HOWEVER once up n running if shes wired right n charging as RPM increases it should swing over in the + charge direction. IF ITS DOING ALL THAT LETS LEAVE HER AS SHES CURRENTLY GROUNDED. Caution,,,,, ,, I wonder though about a VR thats labeled POS ground being used on neg ground. It could work but not last as long due to the way they coat the relay contacts IE NO WARRANTY ON THE VR LOL 2) The coil terminal wiring should match your ground. If youre at Neg ground, the - of coil goes to distributor and + gets voltage from IGN switch. If youre at Pos grnd, + of coil goes to distributor and - gets voltage from IGN switch. 3) The (L)OAD terminal on the VR is wired to the lights or Ignition switches to supply them voltage. Thats often? labeled BAT on a switch, but it may not be. REGARDLESS, the switches hot input feed gets voltage from the VR's L terminal and the other wire is what connects to lights (on a light switch) or the Coil (on an Ignition switch) The VR's L terminal supplies voltage TO the switch(es) and they in turn when switched to ON wire/connect to the lights or ignition coil. Bed time, post back any more questions for tomorrow, good luck n God Bless John T
